Montgomery, AL
pastmyprime214
1/9/2018 11:07pm
1/9/2018 11:07pm
I rebuilt the master cylinder after finding a torn seal in it. Tried to bleed, only get pressure on the last half of pull and wheel didn’t spin good at all. Pulled caliper off and wheel spun great. Decided to rebuild caliper. Bleed the system and still only get pressure on last half of pull and wheel doesn’t spin freely. Using a vacuum bleeder to bleed the line. Almost seems like there’s no pressure in the line on release to pull pistons in.
What else can I try? How can I diagnose the problem?
What year KX250f? The newer ones had a rod that runs from lever to MC piston that goes in both ways but if put in backwards will cause the brake to lock up after a few pumps. My kid found out the hard way...........
Post a reply to: Kx250f front brake
