Denver, CO
I was replacing the linkage bearings in my 08 yz450 and I bought the pivot works set. I pressed them all in and I could not get the pin through one of the bearings. I thought the bearing was just bad so I got a oem one shipped. Now once pressing that one in another different one the pin wont go into and it used to. It may be because the needles when sideways.I cant figure out what it is I took all the needles out and put them back in. I can hammer the pin through. Would it loosen up if I put it all together and rode it or Is that a bad Idea? I would think that would be but Idk.
Any tips guys im getting frustrated
Thanks
Thanks
I will be super careful putting the new ones in. I am positve that I could get the bushing in the bearing right after I put the bearing in the linkage so something got messed up after and I have no clue what it was.
Thanks for the info guys
It is good to go now but learned my lesson don't hammer on stuff unless your sure you wanna be hammering on it. Man I should have already known that. Some times in the heat of the moment and I'm rushed I make bad decisions.
Post a reply to: Linkage bearings
