Lehighton, PA
5/10/2018 9:49am
Guys,
I am looking for stack info from anyone who has revalved their mid valve compression using the 18' oem piston. I've already upgraded my 17' to the new 18' midvalve and base valve. I have an FX350 so I have the oem bevel washer and check shim. I am assuming a 0.3mm float. Any base stack settings for trails/scrambles 205# int/ex would be much appreciated. Thanx.
There are lots of settings out there for the stock 2018 bikes
Also,does this #8 (piston rod) come with everything shown on it, like the exploded parts to the left of it (including #10, #12, #14, #27)??
the 2018 piston kit provides the base and midvalve piston and the funky shim.
You might also consider the 2018 air piston and spring guide (#13 i think).
I hate shooting in the dark but I already did an internal seal kit and I still have no compression damping. Now I think it is the seal in #10 that sits on the rod. I can buy the whole shibang for $250 and if I give the crap to a suspension company and make them figure it out they'll probably charge me similar amount anyway and maybe just end up changing that 1 seal.
Also, if the cartridge seal was the problem, wouldnt the loss of damping be on the rebound side? before the oil migrated to the outer chamber and compression damping is lost as well?
I believe you are correct on the loss on both the rebound and the compression.
Post a reply to: Looking for AER Fork Mid Valve Stack Info
