z71will z71will
11/26/2017 8:24 AM
I'm not sure if this is normal or not but I have a Honda cr125 that I'm working on and when I took the pipe off there was black oil that came out the pipe and exhaust flange. Not a lot but I'd say maybe a cup or half a cup? I had only ran it for a total of 20 minutes after the rebuild. I didn't see any oil shooting out the back when it was running. I run a 32:1 oil ratio.
dirtmike86 dirtmike86
11/26/2017 9:04 AM
Is it premix or engine oil?
Reekers Reekers
11/26/2017 9:05 AM
z71will wrote:
I'm not sure if this is ...more
Definitely not normal. 32:1 is a good mixture so it's not that. What ratio was ran before you rebuilt it? Is it possible the oil was in there before the rebuild?
z71will z71will
11/26/2017 10:29 AM
dirtmike86 wrote:
Is it premix or engine ...more
It's 93 gas mixed with bel ray 2 stroke oil
z71will z71will
11/26/2017 10:30 AM
Reekers wrote:
Definitely not normal. ...more
No because I got this bike in a box in pieces and put it all together with lots of new parts. The pipe was cleaned and the cylinder was cleaned and honed and the exhaust flange is brand new.
Whymee Whymee
11/27/2017 1:41 PM
In a 2 stroke motor that we deal with, there is only 2 ways to get excessive oil in an exhaust pipe. Well maybe 3...
1. Unburnt oil in fuel mix. Usually rich jetting.
2. Tranny oil getting sucked into the crankshaft area through the seals. New seals needed.
3. For the third one, tranny oil seeping through the center case sealing surfaces. Did you use the correct sealer? (Yamabond) Or is the sealing surfaces nicked up or not flat? (needs lapped)
These are the only 3 ways that you will find oil in the pipe, short of dumping a cup of oil in there...
A big thanks goes out to Donnie at Morgantown Powersports and RJ at Beaver Creek Cycles
