Sweetwater, TN
9/29/2022 9:37pm
I just bought a new 2018 Crf450r. I brought it home and did a 1 hour break in split into 3 heat cycles like I always do. Toward the end of break in it started making a noise what sounded to me like a valve tick only on deceleration. I brought it in and did my first oil and filter change and checked the valves. I got 0.010 on both exhaust valves. 0.006 and 0.005 on the intake valves. That's in spec according to the owners manual. I took it out again after oil change and valve check and got on the throttle pretty hard a couple times and it got worse. It is a little louder of a tick now and I can now hear the tick at idle, accelerating and decelerating. Can someone please help me I'm sorry this is so long but I needed to explain the whole situation. I posted on thumper talk and no help yet. I've never had a brand new bike give me problems before but this is my first honda.
I have a 17 that sounds very similar. Did you find a resolution on this? Only does it when warmed up. Valves in spec, nothing odd in valve train. Sound is not there cold.
Only thing i can think of is the clearance opens up a little when it gets hot enough to make a noise when the cam shaft hits the rocker arms. Otherwise I am clueless.
Harbor freight sells mechanics stethoscopes for $3. Go get one and probe around your engine while its running. Youll quickly find the cause.
Checked valves, measured top components with mechanical repair book, all ok, replaced piston and rings, exhaust gasket, still ticking hot.
Asked local Honda dealer and got “they are noisy”.
After reading this thread I will ignore the ticking, would of course be nice if someone found how to get rid of the ticking.
Post a reply to: Please Help 2018 Crf450r valve tick??
