Bethania, NC
Alec138
11/1/2018 6:14pm
11/1/2018 6:14pm
Forgot to add the copper washer when i installed my new drain bolt so it leaks a little bit. Is there anyway to remove the drain bolt without draining my brand new oil i just put in? Thought of laying it over on its side but which side so i lose barely any oil?
JUST PUT NEW OIL IN FOR THE LOVE OF GOD
top off after you are done
PLEASE use a torque wrench. No need to crank on those drain bolts.
Unless your doing it at less than manufacturers spec?
I've always done mine by feel
:-) so have all the people that have cracked the shit out of the crankcase halves
However mates have with torque wrenches....
So your saying that would be a higher torque setting than 15nm without oil?
Post a reply to: Removing drain bolt without draining oil?
