Summerville, SC
My buddies Kawi only made it 3 or 4 laps around the track this weekend before he started to realize the forks wouldn't rebound properly. The initial part of the stroke seemed fine but with larger compressions the forks would stick, or bind. Made a clunk sound when rebounding. We thought maybe the front wheel/axle was binding so we removed and replaced it. No change. Checked the air pressure and though it was a little off, it wasn't drastically incorrect. Topped off the inner, outer and balance chambers using the phone app suggested settings. Still no change.
No leaking oil from dust seals.
Any insight?
Any insight?
After trying everything with these damn forks (including skf Glide Kit), still felt like riding a damn chopper. I threw it on the stand in garage, set the inner at 181 psi, outer at 1 psi (for a little bottoming control) and balance 195 psi. Took a before and after measurement from floor to grip, and gained 1.5 inches (explains the stink bug feeling I was getting). Took it for a spin in field by house, and not a spring fork by any means, but almost night and day difference. I also added another 5ml for a little bottoming control just to be safe.
It was night and day different on mine.
Oh, and if you let the air out so you can open the left leg to add oil, don’t forget to open the bleed screw on the left leg once you inflate the right. Don’t ask...
Post a reply to: Showa SFF Air TAC forks ('16 KX450F)
