- Pick trends
- Create a private league
- And more!
Different forks and clamps, correct?
Is it the KX500 stem in the newer forks clamp?
This is likely the best and safest plan...of course unless none of them had a tight press fit and the replacement clamp ends up doing the same thing.
It keeps the stem from going in too far.
I have pressed out a few KDX and KX stems. It's either a circlip or a shoulder (maybe a combo)
I got the front end back together today and the stem never moved, so I must have seated it properly after running it through the press again. I marked the stem with a sharpie to monitor it’s movement, if any.
Post a reply to: Steering Stem Problem
