Yamaha Power Tuner IOS 14.0 problems
2019 YZ250F, power tuner was working perfectly, after updating to IOS 14.0 it now doesn’t work. Anyone else having this problem? I have tried all the obvious solutions I.e. disconnect CCU, forget network and re load, delete app and re install... Thanks
sandtrack315
Philadelphia, PA US
9/23/2020 5:31pm
2019 YZ250F, power tuner was working perfectly, after updating to IOS 14.0 it now doesn’t work. Anyone else having this problem? I have tried all the...
I’m having this problem too. It connects for a second and I can see my hour meter and what not, and then it disconnects. My other WiFi things that work like the power tuner work fine though.
9/23/2020 8:02pm
Exactly what is happening on mine. I tried my iPad and an iPhone that work fine so I am thinking the power tuner app by Yamaha need to be updated to work with IOS 14. Or a setting change had been pushed out with IOS 14 that is causing it to not work. Frustrating!
sandtrack315
Philadelphia, PA US
9/24/2020 8:21am
Yeah I still can’t figure it out. How do we contact Yamaha about this?
40acres
Houston, TX US
9/24/2020 10:59am
You should be able to report an app issue directly from the app. It will notify yamaha.
Post a reply to: Yamaha Power Tuner IOS 14.0 problems
