NV
About a month ago, i noticed shavings in my oil filter. Immediatley tore the whole engine down, and did a full rebuild on the motor. Top and bottom.
The problem i face now is i am getting lots of coolant coming out of my weep hole under the water pump on the right side. A leaking head gasket would add pressure to my radiators thus causing it to over heat. However no coolant comes out of the overflow.
I replaced the water pump seal again and fired it up only to get the same problem. Im leaning towards the shaft seal. Input?
Post a reply to: breaking point with my 250f
