rm carb question
zac_k3
TN US
Would a rm250 carb work on a rm125? The 250s use kehin and the 125s use mikunis but they look very similar to each other, I'm not sure on specs though.
Bruce372
9/17/2017 10:34am
It would work, but not that well. And I bet it would be a lot of work to make it work well!
I ran a pwk Kehin non power jet carb and it needed a really rich slide.
Save your self a lot of time and money and get the stock carb setup or replaced
zac_k3
TN US
9/17/2017 10:57am
Bruce372 wrote:
It would work, but not that well. And I bet it would be a lot of work to make it work well! I ran a pwk...
I wish I could find one so I don't have to just buy a lectron!
imoto34
TN US
3179th
9/17/2017 11:18am
Keep checking eBay
lumpy790
York, SC US
9/18/2017 5:41am Edited Date/Time 9/18/2017 5:42am
zac_k3 wrote:
Would a rm250 carb work on a rm125? The 250s use kehin and the 125s use mikunis but they look very similar to each other, I'm...
What do you want the 250 carb for?
In the past I bored the 125 carb for more top end and less bottom end on a massively ported cylinder for a VERY GOOD rider. Very different jetting you had to figure out too.
Bruneval
Bristol GB
9/18/2017 7:17am
The stock carb on the 04+ works extremely well. I haven't got the time to test and adjust jetting these days, so used the JD jetting kit and it was perfect straight away in the UK using 99 octane pump fuel (32:1 Castrol A747) at sea level.
zac_k3
TN US
9/18/2017 12:18pm
Bruneval wrote:
The stock carb on the 04+ works extremely well. I haven't got the time to test and adjust jetting these days, so used the JD jetting...
funny you say that.. I just found a 04 carb on eBay. will it bolt right up to the 06?
Bruce372
9/18/2017 12:37pm
yes it will, but it doesnt run a powerjet like the 06rm125 does.
It should work OK, but you might have to work to dial it in.
Bruneval
Bristol GB
9/18/2017 1:29pm
I forgot about the powerjet. I think it was 2005 that they came with that. Here's a picture of one of my RMs which shows it (black plastic sensor is the TPS I believe):
zac_k3
TN US
9/18/2017 5:39pm
So what's everyone's opinion, should i buy the 04 carb or go the lectron route? The thought of no jets has me wanting to go with the lectron but the stock carb price has me thinking it's the better option.
Hondas4Life3
Louisburg, KS US
9/18/2017 9:21pm
zac_k3 wrote:
So what's everyone's opinion, should i buy the 04 carb or go the lectron route? The thought of no jets has me wanting to go with...
I personally would hold out until I found a stock 05-08 powerjet carb
Post a reply to: rm carb question
