- Pick trends
- Create a private league
- And more!
It sounds like stock squish is around 1.5mm and 1.1mm is more optimal
Is good for this
A touch wider if running oxygenated fuel.
Couldn't the supplier tell you this ?
F1 Moto possibly the best VHM dealer in the world !
It should be squish clearance.
Here's how to check it.
https://www.youtube.com/watch?v=NDnZk53AxA4
Hope this helps ?
It would be nice to know the stock gasket thickness so I would know what gasket to order.
I appreciate that running a thinner gasket will lower the exhaust port, but I am fine with that small amount for the sake of dialling in the combustion.
Measure what base gasket you had in at that.
Now subract 0.2mm from the base gasket thickness to give you your desired 1.1mm squish.
Hey presto job done.
You would also be well advised to take a look at these.
https://www.f1moto.com.au/buy/ktm-125sx-2016-2018-performance-power-val…
I was hoping to order just one gasket lol.
You have some cool stuff, keep on smoking!!!!
Post a reply to: vhm head sx chamber 18 sx150
