St. Petersburg, FL
7/27/2019 3:47am
These chains look bad ass & have a slight weight savings as well so I was thinking of pulling the trigger on a trick YZ250 build project. Problem is that bad boy is $$$... I don’t mind spending the $ but not on a consumable / wear item if it isn’t worth some benifit or will last. I usually run a Sunstar mxr1 or DID DZ2 so I don’t buy cheap chains to start with. Lmk if you guys have tried them, how long they last or held up & if it was a weight savings. Thanks!
Post a reply to: EK 3D MXR chain
