Looking for a video highly detailed on how this job is done. 2001 Honda cr250r complete bike swap. Found a crack on my main frame need to swap everything over . Mechanically inclined just looking for a good video i can follow . Any suggestions
These bikes are pretty simple when youre not opening the engine. I agree with Ryan, just go for it. Just make sure you take good pictures for cable/wire routes and you should be all set.
Swing arm, rear wheel, back brake caliper and pedal, linkage and shock all as 1
Just look at it good before you take it apart and you'll figure out ways to get as many pieces off as you can. Also loosen all the bolts before you take it off the bike, it's easier to do on the bike than holding the part in your hands.
When I did mine I took everything off and apart and it didn't take me more than a few hours in the afternoon to get it apart, and then few more hours to get it back together. It's an easy weekend job to do.
And the big thing, put the bolts back in as soon as you take the part off, that way you don't have to bag them and they will be in the correct spot and correct order. Or even swap them over to the new frame where you can
Post a reply to: Frame Swap! Cracked Frame replacement.
