Bardstown, KY
I need parts for my 71 Yamaha dual carb 2 stroke oil injected engine (basically everything but the casing for the engine) and I was told theres a shop in America that sells new old stock and I was wondering if anyone knew who owns that
http://www.speedandsportinc.com/
eBay should be a good source as well. If you can get OEM part numbers, it helps hunt down more affordable solutions.You might consider a solid core motor and if you a mind to, swap the internals into your cases.
Good luck!
joe
Post a reply to: My 71 yamaha parts
