Title says it. My CR started leaking oil last Saturday. It's dripping from the weep hole between the cases. See below, above #15.
Originally I thought it was the center case gasket. But I am wondering if it is related to the clutch arm oil see behind the ignition cover. See below. My oil seal is definitely pushed out of place, and possibly torn. Some oil was present behind the ignition cover.
Anyone have any input?
I just figured i would ask before I start splitting cases. The engine is already sitting on the bench. I noticed the leak while it was sitting on the stand not running after first practice.
Thanks!
Thanks!
Make sure it is the rear weep hole. I think there are 2 holes along the center-line of the cases. A front and a rear. I would go check but have a skid plate in the way.
Disclaimer: Could be wrong about everything I said.
Thank you all.
Post a reply to: 03 CR250R Leaking Transmission Oil From Weep Hole
