Mount Pleasant, PA
I bought a 2009 KX250F that needed a top end rebuild so I put in a Vertex stock bore 13.9:1 compression piston and a Cylinder Works stock bore cylinder. After assembling everything I discovered that the intake valves are hitting the top of the piston and wont allow the motor to turn.. I've triple checked the timing and it is dead on.
Any help would be much appreciated. Thanks.
Backwards piston is also a good suggestion.
If so, what were they?
Have you cleaned the carb?
Do you have fresh gas in he bike?
Post a reply to: 2009 KX250F Intake Valves Hitting Piston
