Honda CR carburettor help
Could anyone help me out. I’m looking at buying a Keihin PWK carburettor for my 2003 Honda CR 250 but do not know the exact carb I need?
H4L
8/16/2018 9:13am
Long body 91 mm from a 2000 CR250 or 99 model will be your best option. The 99 had a richer slide than the 00 model.
8/16/2018 10:45am
JD Jetting is a great source for these carbs. They’ll include a jet kit. I think they are about $270. Not bad when you consider the jet kit is $80. I just put one on my 2004 CR250. It has never ran better.
H4L
8/16/2018 12:14pm Edited Date/Time 8/16/2018 12:19pm
I’ve added a link to an eBay item. Would you be able to tell me if this is the correct carb? Many thanks for your help...
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2F…
That appears to be a screw top Keihin carb which is the older style that fits the 02-03 CR2. It's a 39mm which isn't a bad thing, but the 38mm is the popular choice as it will give better lower end response.
I'd suggest emailing the seller & ask if it's a PWK quadvent. That's the good one IMHO.
8/16/2018 12:49pm
H4L wrote:
That appears to be a screw top Keihin carb which is the older style that fits the 02-03 CR2. It's a 39mm which isn't a bad...
Thanks very much. I don’t know much about them so appreciate your help. The seller has 2 other keihin PWKs. Is the short body the one I’d need? Linked that below
BR8ES
Bennett, CO US
8/16/2018 2:26pm
No... you need the screw on cap style.
H4L
8/16/2018 6:33pm
Thanks very much. I don’t know much about them so appreciate your help. The seller has 2 other keihin PWKs. Is the short body the one...
No, as BR8ES mentioned. That is the short body Keihin with tps that works better for the 04-07 CR2 models.
Post a reply to: Honda CR carburettor help
