SE
1/28/2018 1:48am
Looking for opinions on the different systems that are avaliable for the orange and white siblings, more specifically the following: HGS, Yoshimura, Akrapovic, however thoughts on other brands are also interesting.
Even if you have the opinion that exhaust systems are useless on a 450 please say so and explain your thinking behind it, I am also happy to hear any advice on how to make the bike better in other areas.
As far as making any bike better you start with suspension. $1000 in suspension is better than $1000 elsewhere by far.
Should have stated it in the original post, I have Öhlins suspension so all set there.
The only issue with the stock header, it's heavy but a major pain to remove
Good looking bike btw, love the blue.
Porting, compression and mapping only!
FMF is part of the major stand out KTM backed teams because the product works. Some of the Factory editions come stock with FMF.
The stainless steel version is 250-300€ cheaper than the FMF.
For the other areas i can recommend that you buy a set of 22-24mm adjustable Xtrig ROCS clamps. The 24mm offset makes the bike a bit more stable(22 is stock).
this engine is setup for higher altitude, mega compression and porting and the mapping to make it work.
Post a reply to: SXF/FC 450 16-18 Exhaust system
