Switching oils in 2017 crf450
MxProdigy17
Brick, NJ US
Edited Date/Time 9/28/2017 10:30am
Hey guys I just purchased a 2017 crf450 from a guy that had 9 hours on it using belray thumper oil. I have always used rotella oil in my previous bikes and still have a few gallons of it left over. Am I good to switch over to this oil or do I need to keep using what he used? I remember hearing mixed feelings on rotella as well so wanted to be clear before I go dumping it in a newer bike.
Tyler
Acidreamer
Mansfield, OH US
9/20/2017 9:07am
As long as its the correct weight it should be ok.
Tons of people love rotella. I just tried it in my kx this oil change period. So far no issues after 2 rides.
Ive always ran full synthetic from maxima or amsoil simply because i know its made specifically for bikes. Rotella seems to be a "catch all" oil. Im sure its totally fine but its a peace of mind thing for me to use maxima or amsoil.
mxb2
Bowie, MD US
9/20/2017 9:38am
Gn4 .
Benton, LA US
9/20/2017 10:22am
If you want to use rotella be sure you use Rotella T6 as it is their best. I have used it for some time and love it.
526
Colgate, WI US
9/20/2017 11:06am Edited Date/Time 9/20/2017 11:07am
Is it a Diesel? I am having a hard time wrapping my head around why people use Heavy Duty Diesel Engine Oil In a NON Heavy Duty Diesel Engine?
Shell ROTELLA® is proud to announce a change to our hardworking portfolio of heavy duty diesel engine oils. We wanted to create the most technically advanced Shell ROTELLA® formulation ever. And we did. We also aimed to clearly organize our portfolio so you knew which oil to choose. The full portfolio of new products that meet API CK-4 and FA-4 performance standards are on the market starting in December.
Benton, LA US
9/20/2017 12:15pm
Rotella T6 is a good oil for any engine and is approved for wet clutches. You will find many good oils are rated for Deisels as well, but most are not approved for wet clutches. I use it in my bikes, motor home and generators. It is the best oil I have ever used. When I change my bike oil, the old oil looks very clean and thus I know I have good protection.
The oil T4 was good , but the newer T6 is great.
CarlinoJoeVideo
Portland/Los Angeles, CA US
2361st
9/20/2017 1:33pm
Paw Paw wrote:
Rotella T6 is a good oil for any engine and is approved for wet clutches. You will find many good oils are rated for Deisels as...
I'm still on the T4, what have you noticed different with T6? Longer intervals?
Benton, LA US
9/20/2017 3:08pm
Yes it is a much cleaner running oil and I have much less clutch drag with it and it stays clean telling me that it is doing a better job of lubrication. The next time you change your oil, smell it. Does it smell burnt and is it dirty?
You will not see that with the Shell Rotella T6.
captmoto
Rancho Cucamonga, CA US
9/20/2017 5:47pm
Is that the 15-40 that you guys run?
9/20/2017 5:59pm
I stick with Lucas. Peace of mind that they make oil for high rpm thumpers.
MxProdigy17
Brick, NJ US
9/20/2017 6:05pm
Thanks guy's, yeah I'll just stick to it then. I have been running it in my 13 Suzuki since day one when i was told about it and it's done me good for 100 hours with no issues. I just wanted to make sure I am good to switch over once I run out of the bel ray he gave me. I definitely agree their is a bit more peace of mind running something specifically made for the bikes but I have heard pretty much only good things about it. I just change it every 4 hours rather then 5 and the amount I save in the oil alone is pretty hefty using rotella.
CarlinoJoeVideo
2361st
9/20/2017 8:18pm
I run 10-30 in my 250f, change it every 3 rides and the oil filter with every other oil change.
9/21/2017 6:46am
Thanks guy's, yeah I'll just stick to it then. I have been running it in my 13 Suzuki since day one when i was told about...
Just FYI, Bel-Ray recommends 15 hour changes on that oil.
Give us some feedback when you make the change. I'd like to know if you notice any difference between the two.
YamahaJT1
VA US
9/21/2017 8:24pm Edited Date/Time 9/21/2017 8:54pm
Lubrication freaks howled in agony when SOPUS switched the syn 5W-40 Rotella T name to the new T6 designation around 2012 IIRC... "They ruined it!" and panic ensued to stock up on "the last of the GOOD stuff".
VOA analysis by me and others saw a slight drop in ZDDP , a bump in Phos, Calcium, yadda,yadda, in the "new" T6 formulation. UOA proved otherwise, and it was the best damned overall formulation to date concerning wear... Incredible HTHS,,, 4+ range with decent flow on cold start.
The old 5W-40 Rotella T didn't even have a JASO spec for wet clutch operation, yet smart folks were filling 2/4-stroke transmissions with it based on VOA and UOA.. Thus the legend was born for Rotella T 5W-40 synthetic.
I found an old "Humpback" Rotella T synthetic 5W-40 jug half full in my basement the other day, 2009 date. No JASO-MA spec at all. The label slogan says "Shell Rotella T. IT BELONGS IN YOUR TRUCK".®"
Shell Rotella T6 5W-40 MEETS wet clutch JASO MA/MA2. Pure and simple approval. Not ambiguous "Meets or Exceeds" marketing bullshit.
Shell Rotella T6 5W-40 is arguably the best overall oil ever for me... YMMV. I began using it around 1995 in the various formulations. Here is a range of engines that it covers, approved oil rating or not. Your call there. All these still run. WELL. I guess I take risks, but base them on oil composition/formulation.
1983 Tecumseh 3.5
1998 1.9 VW TDI
2003 VW 2.0
2004 VW 1.8T
2010 Kawasaki FJ180V
2012 Honda CV160 x 2 Commercial and Industrial
I just rebuilt two Honda CR125 engines to include full clutch rebuilds/cranks/every bearing.... Ran the Pro Honda HP Trans for the heat cycles and short rides... Rotella T6 5W-40 forever henceforth until I need to evaluate another reformulation.
Best bet? Consult your manual.
Paw Paw has my vote here. 100%
YamahaJT1
VA US
9/21/2017 9:28pm Edited Date/Time 9/21/2017 9:34pm
I took a pic of the old Rotella T 5W-40 jug just now.
So who thought this was a viable alternative for a wet clutch ripper? Hmmm.... LOL. It IS.
9/22/2017 6:48am
Well it doesn't actually have the approval. Hence it doesn't have the JASO icon:
Nor is it listed on JALOS's website: http://www.jalos.or.jp/onfile/pdf/4T_EV_LIST.pdf
Though they do make the claim and there is no reason to really doubt it that I've seen. My argument is mostly semantics between "JASO registered" and "claim compliance".
526
Colgate, WI US
9/25/2017 1:16pm
Still not getting the connection with running Diesel Truck designed oil in a NON Diesel they are two completely different motors.
imoto34
TN US
3179th
9/25/2017 3:19pm
Rotella diesel oil is not just for diesel engines, it protects the gas engines just as good as what ever oil you use in your bike now.
CarlinoJoeVideo
2361st
9/25/2017 4:09pm
From Shell, "Yes, Shell Rotella T Triple Protection Oil SAE 15W-40 would be an excellent choice for your application. While the product is primarily marketed for diesel engine applications, it does also meet the requirements of API SM for use in 4-stroke gasoline engines. More importantly for your equipment, it also meets the requirements of JASO MA and MA2 for use in wet clutch-equipped bikes."
http://m.vitalmx.com/forums/Moto-Related,20/Shell-Rotella-Oil,1252557?p…
526
Colgate, WI US
9/26/2017 4:53am
imoto34 wrote:
Rotella diesel oil is not just for diesel engines, it protects the gas engines just as good as what ever oil you use in your bike...
It is designed and clearly marketed around Diesel engines, Heavy Duty Diesel engines which are completely different than a 4 stroke motorcycle engine. The running temperatures, fuel type, run time duration, compression etc..... Again JMO
imoto34
TN US
3179th
9/26/2017 4:55pm
526 wrote:
It is designed and clearly marketed around Diesel engines, Heavy Duty Diesel engines which are completely different than a 4 stroke motorcycle engine. The running temperatures...
Sometimes people just need to widen their views on new and different options. Best thing to do if you don't understand something is to educate your self about it. The big ol internet has more uses the dirtbikes and porn.
526
Colgate, WI US
9/27/2017 8:32am
imoto34 wrote:
Sometimes people just need to widen their views on new and different options. Best thing to do if you don't understand something is to educate your...
Yea trying to research why to run Diesel Engine Oil in my 4 stroke Dirt Bike keeps coming back with "Go Ride They Already Designed Oil Specific For This Application" "Don't reinvent the wheel"
slipdog
Nor Cal, CA US
9/27/2017 9:31am
Fuck, I was running Yamalube in My Husky... It must be ruined!
BobPA
PA US
9/27/2017 9:38am
I use basic Pennzoil in my two stroke transmissions. Been running it since '99 or so...no issues thus far. Oil is oil as far as I have seen, everyone has their own oil theory. But, I cannot recall ever seeing an engine fail because of lack of oil protection.
Carlino, I have seen you mention you run 10w30 before, is there any reason for it? The manuals state to run at least a 50w oil. I would think with the high RPM and heat these engines produce, a 30w would not be substantial. I ran Mobil 1 for years in my four strokes, switched to Bel Ray a few year ago because I get it cheaper.....Engines have looked good either way.
Squirtlege
Neptune Beach, FL US
9/27/2017 9:49am
Why would they spend the money to market their product to an incredibly small market sector like Moto, when they are already highly regarded by the diesel market? Just because something isn't marketed directly to a sector, doesn't mean it's not worthy.
BTW, I run Rotella in my Diesel which regularly sees 1400 degree EGT's, 100 degree Florida heat in stop n go traffic, has 190k miles, and 7500 mile service intervals... It will hold up just fine in your bike with the short service intervals we are using. Or feel free to keep buying that expensive shit and paying for someone else's marketing costs. Your call Smile
CarlinoJoeVideo
2361st
9/27/2017 9:50am
BobPA wrote:
I use basic Pennzoil in my two stroke transmissions. Been running it since '99 or so...no issues thus far. Oil is oil as far as I...
I run 10-30 because it's less drag on my 250f. I don't recall exactly what own recommends.
I've been using the Rotella T 10-30 since 2011(knock on wood) no problems,in 4 different bikes. Currently my 2016 I ran 75 hours all stock then a full rebuild with high comp piston, new bottom end, etc that has 50hours(new piston at 25).
I change the oil every 3 rides(3-5hours) so it hardly has time to breakdown. I've had good luck with the oil and intervals, so I just keep doing it. Twisted Development does my engine work and said everything looks great, don't change what I'm doing.
I think the moral of this thread is that each rider has to do what they are comfortable with and can afford. I was skeptical about "diesel oil" in my dirt bike also. But originally it was recommended to me when I used a Rekluse clutch. Rekluse said it was the best oil for their systems at the time. Not sure what they say now.
BobPA
PA US
9/27/2017 1:31pm
I run 10-30 because it's less drag on my 250f. I don't recall exactly what own recommends. I've been using the Rotella T 10-30 since 2011(knock...
Makes sense to me. I am on the same oil change interval as you. My oil always comes out clean
526
Colgate, WI US
9/28/2017 5:26am
Squirtlege wrote:
Why would they spend the money to market their product to an incredibly small market sector like Moto, when they are already highly regarded by the...
Again JMO My Bike was $10K $6 a QT seems like a good investment to me
I run 87 octane in my lawn mower and its 25 yrs old and never had a problem that is Obviously good fuel maybe I should quit buying the expensive 93 octane for my dirt bike that they screwing me on?
Squitlege
Jacksonville Beach, FL US
9/28/2017 7:06am
Geezus christ... yea, you should probably do that brahhh
imoto34
TN US
3179th
9/28/2017 10:29am Edited Date/Time 9/28/2017 10:32am
526 wrote:
Again JMO My Bike was $10K $6 a QT seems like a good investment to me I run 87 octane in my lawn mower and its...
Its obvious 526 is a fucking douche bag that is just wants argue because he is illiterate about engine oil and must have overpaid for his KTM. Are you really asking a message board if you should start running 87 in your bike? How do you go from engine oil to gas? You sound just like my x. Bitch that just wants to argue because shes a bitch.
The chances are you don't change your oil as often as us core moto guys who puts a few hundred hours a year on their 4 strokes.
Post a reply to: Switching oils in 2017 crf450
